Grafana v9.1.4 -
We are trying to create dashboards in Grafana using Cloudflare worker metrics -
We are using the Grafana ClickHouse as a data source to get metrics from the Cloudflare Analytics engine. -
What happened?
we are encountering issues when trying to execute the following query to obtain an aggregated time series of various error codes for each time block.
We are referring the following document - clickhouse-grafana/README.md at master · Altinity/clickhouse-grafana · GitHub
$columns(blob4, count(*) c) FROM "T_API-staging" WHERE (blob1 = 'success') AND (double1 = 0);
Which should be computed as:
SELECT
t,
groupArray((errorCode, c)) AS groupArr
FROM
SELECT
(intDiv(toUInt32(timestamp), 60) * 60) * 1000 AS t,
blob4 AS errorCode,
count(*) AS c
GROUP BY
t,
errorCode
ORDER BY
t,
errorCode
GROUP BY t
ORDER BY t
Instead of getting the data, we got the following error
Input was invalid: sql parser error: Expected an SQL statement, found: $columns
If we try to write the computed query directly, so don’t use the macros, we got this error instead:
Input was invalid: unsupported expression type: (errorCode, c)
Could someone please assist us in obtaining the relevant data from the Cloudflare Analytics engine?
Getting the data from Cloudflare Analytics engine -
Already mentioned on - What happened? -
I really appreciate any help you can provide.
