Data missing time field
    Windows
    Plot cnadlestick time series data
    Through clickhouse query
  • What happened?
    Getting “Data missing time field” error
    To see a candlestick chart, i can see table view and has time field
SELECT toUnixTimestamp(TimeBarStart) as time, FirstTradePrice, HighTradePrice, LowTradePrice, LastTradePrice, Volume FROM “algoseekTAQ”.“us_equity_1min_taq” WHERE ( time >= $__fromTime AND time <= $__toTime ) AND ( Ticker = ‘${Ticker}’ ) ORDER BY time ASC LIMIT 1000
    No
welcome @svctradingbqm
Why are you doing the following
toUnixTimestamp(TimeBarStart) as time What data type is TimeBarStart
It’s datetime64 type in clickhouse database. Looks like below in table view
what does it look like if you dont use that function but rather use convert field transformation and convert it to time
Not quite sure what you mean. Without that function, raw data looks like below. Is the error due to time format issues or time column not being there? I do see ‘time’ column
time
2020-01-02 09:00:00
2020-01-02 09:01:00
2020-01-02 09:02:00
2020-01-02 09:03:00
2020-01-02 09:04:00
2020-01-02 09:05:00
2020-01-02 09:06:00
2020-01-02 09:07:00
2020-01-02 09:08:00
2020-01-02 09:09:00
2020-01-02 09:10:00
2020-01-02 09:11:00
2020-01-02 09:12:00
2020-01-02 09:13:00
2020-01-02 09:14:00
2020-01-02 09:15:00
2020-01-02 09:16:00
2020-01-02 09:17:00
2020-01-02 09:18:00
2020-01-02 09:19:00
2020-01-02 09:20:00
2020-01-02 09:21:00
time format. the datatype might be string date and grafana some versions have issues with that. so you can use transformation to convert to time
I took out toUnixTimestamp function and don’t see that error anymore. thank you
I’ve a different issue now. I am using candlestick to display this data. Numbers are float, however tool tip shows integers. Any idea how to fix? Thank you
same thing, use convert to convert to number maybe?
