v10.0
OS is Win 10 Entreprise LTSC
SQL Server Express is 19.1 (2019 -
Build a Dashboard, add a time series -
With the Query builder -
What happened?
I always get the error ‘Data is missing a time field’ -
See time series -
Introduction to time series | Grafana documentation
I create a column in the DB with contains the Unix timestamp value.
How do you tell Grafana that this column is a time field?
