Data Manipulation Plugin Not Displaying Leading Zeroes for Float Values while input
Hello Grafana Community,
I’m currently using Grafana with the Data Manipulation plugin (version 3.1.0), and I’ve come across an issue that I’d like to discuss with you. When I choose the “number” format to display float values, the plugin is not showing leading zeroes for values less than 1. For instance, 0.5 is displayed as “.5,” and I would like it to show as “0.5.”
I kindly request your assistance and insights. If you’ve encountered a similar problem or have suggestions for a resolution or workaround, please share your knowledge.
Best regards,
Utkarah
#volkalab #data_manipulation plugins
Opened issue in the GitHub repository: Data Manipulation Plugin Not Displaying Leading Zeroes for Float Values while input · Issue #247 · VolkovLabs/volkovlabs-form-panel · GitHub
I will take a look and get back to you.
