Hi everybody, is there a way that i can user the ${__value.text} with an toLower that i generate an URL witch only have lower case?
How is the value list generated in the first place
What visualization are you using?
It is an influx Querry and i´m using the Table output.
So the Value Return with a String in the cell. At the moment i use the string with Override and Datalink. In the URL i have somthing like: https://someurl.com/${__value.text} but i need the "${__value.text} in lowercase
Hi @matzeeg3,
Here is a solution that worked for me:
First I created Flux query that converts letters to uppercase for each row by calling strings.toUpper inside map() function. I used last() to get only last values and group() so that I get all results in single frame/serie/table (in other words so that all data is shown in table without having to change frame).
Query:
import "strings"
from(bucket: "test")
|> filter(fn: (r) => r["_measurement"] == "net_response")
|> filter(fn: (r) => r["_field"] == "result_type")
|> map(fn: (r) => ({ r with HOST_UPPER: strings.toUpper(v: r.host) }))
|> keep(columns: ["_time", "_field", "_value", "host", "HOST_UPPER", "port"])
|> last()
|> group()
Then I set up an override that applies only to “HOST_UPPER” column and set Data link
Data link:
http://192.168.101.131:3000/d/fkwAvHo4k/linux-hosts?orgId=1&var-Server=${__data.fields.HOST_UPPER}
Result:
In URL you can see that string is shown in uppercase.
Tested on:
Grafana 9.3.2
InfluxDB 2.6.1 Flux language
Best regards,
ldrascic
I have the same problem.
Is there a solution more simple than ?
Simethink like ${__value.text:toLower}
