My grafana.ini has:
[dashboards.json]
enabled = true
I have put my dashboards in /var/lib/grafana/dashboards. When I login to the UI I see all my dashboards appear twice in the list of dashboards. The duplicates point to the same link, so that if I am on dashboard A and I try to click on the duplicate dashboard A, nothing happens (it thinks I’m clicking on the one I’m on but I am actually clicking on its duplicate).
The dashboards are also not editable – only if I “Save As” can I then edit them.
I am running Grafana on Openshift.
Any suggestions?
