Dashboards > Browse not visible or enabled?
Hi
Hope you can help - Im running Grafana 8.1.2 in docker at home. When I click on the four squares on the left side of the web ui, and click them on the resulting pop out menu, there is no browse option in the submenu available. Where as on my work Grafana who are running 8.4.0, there is a browse option. Is there an environment variable I can set in docker to enable this browse function? Or do I need to upgrade my Grafana version to be able to see this?
Ive tried searching for this however I must be using the wrong keywords as I cant find anything.
Thanks in advance for your help.
Kind regards
Andrew
Apologies for the noise - I simply updated my docker image to 8.4.0 and the browse option appeared :slight_smile:
Hopefully this is helpful to someone else .
