Dashboard variable is not listing all host groups
    grafana 11.3.1 on Oracle linux 9.4
    list all host groups from a regexp.
    using regexp at variable “group” query , and all host groups have permission to read (zabbix plugin datasource).
  • What happened?
    the result should be 6 host groups and it is listing 5 host groups.
    query result 6 host groups
    regexp: /prod/w/.*/
    result : frontend , report, boletos, backend, agv, integration
    (“integration” is missing)
    no errors
    Variable syntax | Grafana documentation
Funny thing is group “prod/w/integration” is a valid entry of a Group item of any panel (table, time series, etc), so it is not related with permission.
What do the working values look like pre regex
Hi, host groups are :
prod/w/frontend
prod/w/report
prod/w/boletos
prod/w/backend
prod/w/agv
prod/w/integration
(and last one is not listed…)
Kindly notice regexp is a small detail , the main point is “why a valid host group is not listed in a variable ?”
regards,
I figure out that I need to explicitly create a host group.
Previously it was created implicitly (when a non existent host group is typed at an host entry).
So, I removed and created again, now variable is working.
regards.
