Facing 404 issue while retreiving hosts in dashboard
    v10.0.1(RHEL 8)
    We are zabbix as datasource and we have a host group which contains around 30 hosts. When writing a Metric query in dashboard in grafana and selecting the group name and writing a regex in host say /XYZ./-- it results in “Request failed:status 404 not found”
    While as observed if i replace regex in host as /ABC.
    / – it works fine. Also, if i try to retrieve all hosts using /.*/ it again result in 404 error.
    Its not specific host issue because if i select single hosts separately it works fine.
Can you please suggest?
Hi Any suggestion?
