10.4.7 Alpine Docker Container -
I want to use a regex to change the panel title that is sourced from a dashboard variable. I only want to change it for the panel title, not anywhere else.
We are trying to change the panel pitle of a repeated panel. The panel title is defined as a variable. Is there a way to do this.
For example, we have a variable ${my_var} which is a list of strings (['svr_alpha', 'svr_bravo', 'svr_charlie']). We want the repeated panels to have a title of alpha, bravo and charlie instead of svr_alpha, svr_bravo and svr_charlie.
I have looked at advanced-variable-format-options but that does not seem to allow me to perform a regex on the panel title.
Is there a way to change the panel title that uses a variable for the name?
