Grafana Cloud -
I have a Prometheus table range query that returns values identified by a port number (I1, I2, I3, etc.). I use a query variable calledmx2_portto get a list of these port numbers, set it to “All”, and set the Grafana panel to repeat by that, so I get 8 panels, for example:
I want to title each panel with both the port number and the port name. The port name is not available in this query, it’s part of a separate info metric. -
I added another query variable calledmx2_port_namedefined aslabel_values(mx2_info{source="$mx2_matrix_ip", port=~"$mx2_port"},port_name). I set this to “All” so when the first variable returns 8 numbers, this variable returns a list of 8 names. I tried to set the panel title toPort $mx2_port $mx2_port_name. -
What happened?
The second variable does not expand, so it says “All” on each panel.
I was hoping the first panel would be labeled “Port I1 Apple TV”, and the second would be “Port I2 Coffee Table”, etc.
Alternatively, I tried searching for a way to use a label from the query results as a variable in the panel. I found a few threads asking for this but no answers, so I guess it’s not possible.
any updates?
