Dashboard List - widget suggestions
I was looking at using the mentioned widget to provide a better user experience with the site. However I wasn’t able to customise as much as I would like…
It be really useful if I could include the ‘description’ field of the dashboard on the widget.
Where do i go to make this suggestion to the maintainer of the widget,
Hi. Dashboard list is part of Grafana core, you can find the source code in the Grafana repository:
you can follow the contribution guide if you want to contribute to Grafana or you can open an issue if you want a feature request.
If you decide to create a feature request, be sure to be clear in your request, include screenshots and all the relevant information.
