Grafana v8.1.3 (a61f38238c) -
I would like to see Dashboard descriptions in “Dashboards” → “Manage” and in panel “Dashboard list”. -
There is field “Description” in “Dashboard settings” → “General”. I’ve filled it up. -
What happened?
Provided description isn’t displayed anywhere. -
I’ve expected the description will be part of item in dashboard list or will pop’up after mouse over -
N/A -
N/A -
I haven’t found.
Hi @grawiku
thanks for starting this topic. Two things: the description appears in the dashboard JSON. Try this:
curl https://play.grafana.org/api/dashboards/uid/000000014 | jq .dashboard.description
And then try it with your own dashboard, replacing the url and uid.
As far as your desire to see the description on the dashboard manager and dashboard list plugin: I think that’s a fantastic idea.
So the best way to get the teams to pick up a community feature request is to start start a discussion in the grafana/grafana repo. Highly upvoted discussions will get traction and picked up by the squads. Recommend you start a discussion and get that going–this is a great idea and shouldn’t be too hard to implement.
