How can I create this kind of download link as a PDF?
Can I use it for Grafana cloud? I couldn’t find that plugin from the library.
No, in cloud you can use reporting feature of paid Enterprise version
Thank you. @ebabeshko . Let me try.
Hi, @ebabeshko .
Can I make download link (one button) in Grafana cloud? Or can you explain some detailed steps to use Grafana plugin?
Thanks in advance.
@serhiidelmuk , as I’ve mentioned earlier, you can use that plugin in your standalone Grafana installation, or you can upgrade your cloud plan to Enterprise so as to use built-in Grafana PDF reporting feature (no additional plugin needed in this case).
How can I install it in windows? I have my grafana running as servicce in windows machine.
Can you help?
Did you follow the documentation? Also check issues that I met during installation on Windows
