Daily consumption shows time in timeline instead of the day
I have a database (Maria DB 10 from Openhab) in this is in 30s cycle the current meter reading.
Now I want to calculate the daily consumption with Grafana and display it graphically from the last days.
The works so far, only he always calculates from 02:00-02:00. I can still live with it. But unfortunately it always shows only the time in the graphic, only when I go over it with the mouse I see the date. How can I change this?
Thanks a lot
welcome to the :grafana: forum, @danieldw
you might want to spend some time exploring the bar chart plugin in Grafana. It uses a different data model than the timeseries panel, so you will need to adjust your data using transformation or on the DB side.
But, it can group values along the x axis according to arbitrary strings, like the days of the week. Perhaps this could work?
Thanks for the tip, I now have
added “Prepare time series”.
Now I have only 2 problems,
  1. The sorting doesn’t work anymore (latest above).
    if I add again “sort by” it does not work
again.
  1. Can I where the format still change, that e.g. the time is not displayed, or the weekday instead of the date?
Thanks a lot
hi,
encountered the same problem. is there any solution?
thanks!
