grafana:12.1.0 running as docker container
- What are you trying to achieve?
Customize dashboard and panel link in email alert notifications, so that I can add query parameters to these links (otherwise esspecially panel links make no sense, because a panel is usually controlled by a variable, so the link needs to have the value of the variable as query param)
- How are you trying to achieve it?
Trying to add DashboardUrl and PanelUrl as annotations with custom value, but the buttons in the email don’t use my custom values
- What happened?
Nothing happens
The dashboard and panel buttons should use the values from the annotations DashboardUrl and PanelUrl.
- Can you copy/paste the configuration(s) that you are having problems with?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No
- Did you follow any online instructions? If so, what is the URL?
Yes, Create and link alert rules to panels | Grafana documentation, and I don’t understand why there are no mentionings of adding variable values to these links.
