Customize classic palette colors
    My general design philosophy for dashboards is that red means bad and green means good. This helps users understand the data quickly. Some data does not have a concept of “good/bad”, so I want to use random colors other than green and red for these panels. Is there a way to customize the “Classic palette” or create my own “custom palette”?
The only alternative I’ve found is to set color overrides on each series, which is a lot of work.
