Hi, I’m developing a datasource plugin for Grafana, and I need it to populate a Query-type variable. The response sent by the plugin is as follows
"results": {
"StandardVariableQuery": {
"status": 200,
"frames": [
"schema": {
"name": "response",
"refId": "StandardVariableQuery",
"fields": [
"name": "text",
"type": "string",
"typeInfo": {
"frame": "string"
"name": "value",
"typeInfo": {
"frame": "string"
"data": {
"values": [
"Option 1",
"Option 2"
"value1",
"value2"
However, the dropdown for the variable remains empty and does not display any options.
What I’ve Checked So Far:
- I used the Query Inspector tool to verify that the request and response are correctly sent from the plugin.
- The response format appears to comply with the DataFrame documentation:
- It contains
textandvaluefields. - The values in the
valuesarray are of equal length and in the correct order.
- Here’s the plugin code generating this response:
func (d *Datasource) QueryData(ctx context.Context, req *backend.QueryDataRequest) (*backend.QueryDataResponse, error) {
res := backend.NewQueryDataResponse()
for _, q := range req.Queries {
frame := data.NewFrame("response",
data.NewField("text", nil, []string{"Option 1", "Option 2"}),
data.NewField("value", nil, []string{"value1", "value2"}),
res.Responses[q.RefID] = backend.DataResponse{
Frames: data.Frames{frame},
return res, nil
Questions:
- Does my response format have any issues that might prevent Grafana from displaying the values?
- Are there any specific settings I need to configure for Grafana variables to work with my plugin?
- Could this issue be related to the Grafana version (v11.3.1)?
Any help or suggestions to resolve this issue would be greatly appreciated. ![]()
Grafana Version: v11.3.1
Thank you in advance!
