Custom permissions in Grafana Cloud
I would like to know if there is a possibility that when I add a user and give them a viewing role, if there would be some configuration so that that dashboard opens suddenly or that only the control panel appears on the sides and no other sections.Could someone help me, thank you.
No, Viewer is basic role, with static list of permissions. But you can create custom role, where you can specify custom RBAC permissions (e.g. read one particular dashboard, datasource only) and then assign that custom role to the user instead of Viewer role.
In theory you can edit also Viewer role, but you must know what you are doing and what are consequences.
Thank you, it will be of great help to me for sure.
