CSV Plugin / path premisssion denied
I’m trying to use csv plugin as a data source. I chosed the local and gave the path to the csv file but it got the error:
stat /home/thefi/test.csv: permission denied
Does anyone know how to solve the problem?
many thanks
Welcome @nizamhalawi21
In the above statement, does this mean you modified your grafana config file? More here.
I already did but still have the same error
Can you change the file or folder permission to allow full access? This does not appear to be a Grafana issue, but a file or folder permission issue.
already did. but still have the sme error
put the file in /opt
same issue. file has full acccess . chmod 777
Hi @nizamhalawi21
What is your environment on which Grafana is running e.g. Docker, Kubernetes, local virtual machine?
Also, are you using Grafana OSS or Grafana cloud?
Please locate your csv file in /var/lib/grafana/csv/ . Thanx.
