- v12.1.1 and MacOS
- Create an XY Bubble chart where: X axis is time, Y axis is operation latency, and the bubble size is the operation count
- We have separate series for operation latency (
last_exec_micros) and operation count (exec_count_total) that should have aligning timestamps and labels (they come from the same ping)
- Added the two queries (see JSON below)
- Apply “Join by field” with a field that is not time to create a single table (but I see duplicate “Time” columns)
What happened?
- When I select the X (time) / Y (
last_exec_micro) / Size (exec_count_total) field, I just see an “Err” text in the chart - I suspect it’s because I’m not merging the tables on the “Time” field
- A bubble chart with the expected axes to be generated
"datasource": {
"type": "victoriametrics-metrics-datasource",
"uid": "${data_source}"
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisBorderShow": false,
"axisCenteredZero": false,
"axisColorMode": "text",
"axisLabel": "",
"axisPlacement": "auto",
"fillOpacity": 50,
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"pointShape": "circle",
"pointSize": {
"fixed": 27
"pointStrokeWidth": 1,
"scaleDistribution": {
"type": "linear"
"show": "points"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": 0
"color": "red",
"value": 80
"overrides": [
"__systemRef": "hideSeriesFrom",
"matcher": {
"id": "byNames",
"options": {
"mode": "exclude",
"names": [
"Latency"
"prefix": "All except:",
"readOnly": true
"properties": [
"id": "custom.hideFrom",
"value": {
"legend": false,
"tooltip": false,
"viz": true
"gridPos": {
"h": 10,
"w": 24,
"x": 0,
"y": 101
"id": 35,
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom",
"showLegend": true
"mapping": "manual",
"series": [
"frame": {
"matcher": {
"id": "byIndex",
"options": 0
"size": {
"matcher": {
"id": "byName",
"options": "Operation Count"
"x": {
"matcher": {
"id": "byName",
"options": "Time 1"
"y": {
"matcher": {
"id": "byName",
"options": "Latency"
"tooltip": {
"hideZeros": false,
"mode": "single",
"sort": "none"
"pluginVersion": "12.1.1",
"targets": [
"datasource": {
"editorMode": "code",
"exemplar": false,
"expr": "sum(last_exec_micros{process_hostname=~\"($hostname)\"}) by (namespace, hash)",
"format": "table",
"instant": false,
"legendFormat": "__auto",
"range": true,
"refId": "A"
"datasource": {
"expr": "sum(rate(exec_count_total{process_hostname=~\"($hostname)\"})) by (hash)",
"format": "table",
"hide": false,
"range": true,
"refId": "B"
"title": "Latency Over Time",
"transformations": [
"id": "joinByField",
"options": {
"byField": "hash",
"mode": "outer"
"id": "organize",
"options": {
"excludeByName": {
"Time 1": false,
"Time 2": true
"includeByName": {},
"indexByName": {
"Time 1": 0,
"Time 2": 5,
"Value #A": 3,
"Value #B": 4,
"namespace": 1,
"hash": 2
"renameByName": {
"Time 1": "",
"Time 2": "",
"Value #A": "Latency",
"Value #B": "Operation Count",
"namespace": "Namespace",
"hash": "Hash",
"hash 1": "Hash"
"type": "xychart"
- Don’t think I see any relevant errors
- No
