Hi.
I have a problem to configure my grafana dashboard correctly. I read data from an influxDB datasource where there are 2 tables (or measurements), called foo and greeting. Over a time window of 1 minute, these tables contains 600 entries each evenly distributed. This mean that for each second, there are 10 entries in each table, which gives a total of 20 entries per second.
I want to design one query that shows a series over that minute with the Y axis value equal to 20.
I’ve tried many kinds of queries but the result is either that the chart becomes empty, or that it shows a notification for some error that is occuring.
See my query below:
select fcount + gcount from (SELECT count(“value”) as fcount FROM foo WHERE $timeFilter GROUP BY time(1s) fill(null)), (SELECT count(“value”) as gcount FROM greeting WHERE $timeFilter GROUP BY time(1s) fill(null))
This gives me an empty chart. If I just use “select fcount” or “select gcount” they show the respective count value 10.
I have given up on achieving this. I had to rework my DB design. In order to do what I want, I now store all data that I need to aggregate into one series, in the same table (measurement). Instead of separating the different types of measurement from eachother by different measurements, I now do it with different values in a new column. So for my original example above, I store the data from both tables foo and greeting, into a transaction table. This table has a new column called type where the value are “foo” or “greeting”. In grafana I now can design queries with select count(*) from transaction. For queries where I need only a specific measurement, I add: where type = “foo”
