Create custom plugin in Grafana using React and Node.js
I want to create a cusom plugin to show data from sql and user can CRUD on it, is it possible? thanks so much
Hey @maiducphuc2001,
I’ve find this documentation where you can find this part. I don’t know if that’s what your are looking for…
Regards
Thank you so much, but if i use plugin so i have to update grafana’s version and updating version of grafana is difficult
Vào Th 3, 2 thg 4, 2024 vào lúc 15:33 Raymond Sowden via Grafana Labs Community Forums <notifications@grafana.discoursemail.com> đã viết:
Thank you so much, yep! I’m also following this method, but creating a plugin is quite complicated
Vào Th 3, 2 thg 4, 2024 vào lúc 15:11 Codi639 via Grafana Labs Community Forums <notifications@grafana.discoursemail.com> đã viết:
What’s your actual version of Grafana?
Well, kinda yeah haha…
