I would like to get Grafana working as a standalone site in IIS. The docs on IIS have it set up as a sub-path of an existing website, but I do not wish to do this. I’ve tried playing around with the settings, but I am largely unfamiliar with URL Rewrite and ARR, and I can’t be the first person wanting to do this with Grafana and IIS.
8.0.4 -
Have a standalone IIS site called Grafana that loads up to my instance (ex. grafana-test.internal(dot)com) -
IIS, URL Rewrite, Application Request Routing -
What happened?
Anything I do just leads to the generic blue Internet Information Services page. -
Not really. -
No, Grafana itself is still functioning on localhost:3000. I can get the site to work as grafana-test.internal(dot)com:3000, but I would like to avoid using the port if possible, to help with end user confusion. -
Use IIS with URL Rewrite as a reverse proxy | Grafana Labs
Also, sorry for the (dot), it’s just meant to be a period. The forum is making links out of them, and since I’m still considered a new user, it says I can only post two links. Sorry!
