Use IIS with URL Rewrite as a reverse proxy - ERR_TOO_MANY_REDIRECTS
Hello people,
I’ve been trying to configure the Grafana on IIS using reverse proxy but without success.
I followed the steps in the documentation ( Use IIS with URL Rewrite as a reverse proxy | Grafana Labs) and watch a tutorial (Grafana and IIS - Windows Server Installation Setup and Configuration - YouTube), but, I always have the error ERR_TOO_MANY_REDIRECTS in the browser.
Grafana version: 10.0.1.
My custom.ini config:
[server]
# Protocol (http, https, h2, socket)
protocol = http
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port  to use
http_port = 8080
# The public facing domain name used to access grafana from a browser
domain = localhost
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
serve_from_sub_path = true
My web.config:
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
    <system.webServer>
        <rewrite>
            <rules>
                <rule name="Grafana Inbound Rule" enabled="true" stopProcessing="true">
                    <match url="grafana(/)?(.*)" />
                    <action type="Rewrite" url="http://localhost:8080{R:2}" logRewrittenUrl="false" />
                </rule>
            </rules>
        </rewrite>
    </system.webServer>
</configuration>
I don’t know what happens so I need help.
Thanks
Welcome @byander
Why do you want to run grafana via IIS ?
Hello @yosiasz ,
It’s because currently, the company where I work uses only Windows Servers. Unfortunately, for now, I can’t use Linux Server.
I found on Github this issue (Azure AD redirect not working behind IIS reverse proxy · Issue #32034 · grafana/grafana · GitHub) and I put in the “Server proxy settings” and then configure ARR the option “Reverse Proxy” with the value “community.grafana.com”.
The default value is empty and the documentation doesn’t mention this field to set.
When I set it to community.grafana.com, it works but I don’t know if is the best way to solve it.
why not install it as a windows service?
install as service
start
done
sc.exe create _grafana-10.0.0 binpath= C:\LGTM\grafana-10.0.0\bin\grafana-server.exe
@yosiasz ,
I installed it as a service.
But I would like to use the proxy reverse from IIS to Grafana service and this way hide the port from URL.
do you have anything running on 80? on that server
or maybe bypass IIS and use this? been a while since I have done this
Try
This is how I was able to fix it, but then i wonder why it is that IIS is not passing the host header, will try to get back to you on this
Go to your configuration editor at the server level and navigate to this path
system.webServer/proxy
set preserveHostHeader to true, now grafana can be run with enforce_domain = true
Serve Grafana from subpath specified in root_url setting. By default it is set to false for compatibility reasons.
;serve_from_sub_path = false
This is how I solved it
Hey! I meet the same problem. This is how I solve it:
In IIS URL rewrite, replace http://localhost:8080{R:2} with http://localhost:8080{R:0}
. Then the IIS works right.
The doc here need be updated: hhttps://grafana.com/tutorials/iis/
You can not set
with
<action type="Rewrite" url="``http://localhost:8080``{R:2}" logRewrittenUrl="false" />
</rule>
at same time.
should configured with {R:0}.
While
with {R:2}
