7.4.5 -
Trying to build some panels and alerts with data from Snowflake -
What happened?
The panel works just fine but when the alert is built we just get tan error, shown in the error question below. -
I am not able to as it contains proprietary information -
Error: tsdb.HandleRequest() response error &{Could not apply macros: interval: 0s. unrecognized interval unit Could not apply macros: interval: 0s. unrecognized interval unit A [] [] 0xc0025aadb0}
Introducing the Snowflake Enterprise plugin for Grafana | Grafana Labs
We had the intervals set to Evaluate every 6h and the condition set to query(A, 6h, now) as far as timing. I have since updated it to be the defaults on the new monitor and I have note had the error so maybe it’s something to do with how long a window that can be used? I’ll keep playing with this on my end as well.
