Alert configuration with $__interval variable in query
I am using prometheus as data source and I know that the template variables are not supported in alert queries. But, what about $__interval variable?
I don’t see any error message when I click on alert configuration. However, I am getting the following error when I check the state history.
Error: tsdb.HandleRequest() error bad_data: 1:90: parse error: missing unit character in duration
Can someone please confirm the above?
I tried configuring the alert evaluation interval as “1m”
thanks,
Can anyone please share your suggestions?
Hi @anoopmohanpzr.
Did you figure out what is going on when using the $__interval variable? I’m facing the same problem.
Thanks.
I have the same problem, is there any ways to solve it?
