i want to make a visualization about correlation analysis between two table -
i have make a query and the query works well and show the result how i want them to be -
What happened?
but when i want to make a visualization about it, it just doesnt show anything. it keeps saying there’s no Y values -
i want to make a correlation analysis chart -
