So I wanna add multiple servers to my grafana server. Is it possible to do this using command line on Ubuntu for a fast and easy installation, just like the grafana cloud. Also would I need anything else except from grafana on my main server to set this up? And how would I go about doing this?
Regards,
Daniel B
Add other grafana servers?
No I don’t have other grafana servers, I wanna add monitoring to other linux servers through my grafana server. So I would like to monitor all the performances of my linux server on one singular grafana server which I have already set up. But I don’t know how to actually monitor the other linux servers that I currently have and how would I go about attaching them to my grafana server?
that is doable but it will require you to put some stuff together.
- a time series database to collect these metrics in (you cant save it in grafana)
influxdb is a great one - a process that pushes perf metrics from your servers to your TSD
telegraf is a nice service provided by influx and has a lot of templates to use - Then you point your grafana to your influxdb server to visualize these metrics.
I would highly recommend the following if you want to go that route. (there are other options)
