Grafana 4.6.0 community operator from Openshift operatorHub
Linux with OpenShift 4.10 -
I’m trying to set up email alert notifications in Grafana. -
Currently I have Grafana configured with the OpenShift built in Prometheus with Slack alerts. When I try to set up email alerts I get a message that says I need to set up SMT using the grafana.ini file. I looked at the documentation and it only mentions grafana.ini file to enable SMTP. Since I used the Grafana operator, I’m not really sure if this file exits or where to find it? How can I enable SMTP to use email alerts? The only files I have to create were the YAML files to create the Grafana instance and datasource. Do I have to specify SMTP in one of those files or somewhere else? -
Grafana YAML filed used to deploy instance in OpenShift
apiVersion: integreatly.org/v1alpha1
kind: Grafana
metadata:
creationTimestamp: '2022-09-16T21:06:10Z'
generation: 1
managedFields:
- apiVersion: integreatly.org/v1alpha1
fieldsType: FieldsV1
fieldsV1:
'f:spec':
'f:config':
'f:auth':
'f:disable_signout_menu': {}
'f:auth.anonymous':
'f:enabled': {}
'f:log':
'f:level': {}
'f:mode': {}
'f:security':
'f:admin_password': {}
'f:admin_user': {}
'f:dashboardLabelSelector': {}
'f:ingress':
'f:enabled': {}
manager: Mozilla
operation: Update
time: '2022-09-16T21:06:10Z'
fieldsV1:
'f:status':
'f:message': {}
'f:phase': {}
'f:previousServiceName': {}
manager: manager
operation: Update
subresource: status
time: '2022-09-16T21:06:11Z'
namespace: grafana
resourceVersion: '158944'
uid: 3736b3f5-f06b-4f42-98e9-bf1648f545f7
spec:
config:
auth:
disable_signout_menu: true
auth.anonymous:
enabled: true
log:
level: warn
mode: console
security:
admin_password: XXXXXx
admin_user: XXXXXX
dashboardLabelSelector:
- matchExpressions:
- key: app
operator: In
values:
- grafana
ingress:
enabled: true
status:
message: success
phase: reconciling
previousServiceName: grafana-service
