Hello, I’m trying to set up the alert on grafana, I have to configure the smtp in grafana.ini but I don’t know what to put in it. I would like the alert sent to several people (It’s for farmers)
Thank you for your answers.
Are you self-hosting Grafana? Then you will need to set up an smtp server.
If you are using Grafana Cloud, then the email alert notification is already set up and configured on the backend. In that case you simply add their emails in the UI.
