Grafana OSS SMTP Configuration
I am facing issue while configuring Alert Notification via grafana to outlook, unfortunatly I don’t see any such related logs inside pods.
Chart version : grafana-9.3.0
Trying to setup Alert Notification to Corporate outlook email
Tried configuring via grafana.ini,
  • What happened?
When we tried adding contact point in grafana UI, it says SMTP is not configured!
Alert Notification is expected to push events/alerts to EMAIL
grafana_ini:
smtp:
enabled: true
host: smtp.office365.com:587
user: $__env{SMTP_USER}
password: $__env{SMTP_PASSWORD}
# cert_file:
# key_file:
skip_verify: true
from_address: @<domain.com>
from_name: Grafana Alerts
# ehlo_identity:
# startTLS_policy:
# enable_tracing:
# existingSecret: “”
# userKey: “user”
# passwordKey: “password”
ERROR: Failed to send test alert.: SMTP not configured, check your grafana.ini config file’s [smtp] section
I do see SMTP section configured under grafana.ini file.
Could you please assist.
Thanks.
It looks like you are using helm for deployment. Indentation has meaning in the yaml file:
smtp:
  existingSecret: ""
  userKey: "user"
  passwordKey: "password"
vs:
smtp:
existingSecret: ""
userKey: "user"
Check the doc/default values for the used helm chart.
Of course you need to update deployed helm chart, when you change value file.
