Hi grafana team and experts,
I have developed custom themes for Grafana to match the rest of our GUIs.
In order to do this, we changed what we needed and compiled using the Dockerfile that is available on github, until this point, no problem found.
Since I need my images to be certified by RedHat and it seems that you use Alpine I started the conversion of the Dockerfile, but when we are unable to find a equivalent to the musl package.
The dockerfile is able to complete but when we try to run we always get an error that grafana is not found.
Is there anyone that was able to get either custom themes without having to recompile the source code, or run grafana in a ubi9 image after the code is compiled with some changes?
Thanks for your support,
LP
Latest code in Grafana, ubi9 (Linux RedHat) -
To compile a Grafana version with our own themes based on RedHat -
Changing the code to have the themes then running in RedHat -
What happened?
Running /run.sh failing with message: “./grafana: No such file or directory” -
I would expect it to run -
No configuration. -
No
