the latest grafana image in redhat is version 7,
9.4.7 and redhat 8 + kubernates -
Build docker image based on redhat 8 base image with grafana 9.4.7 code -
clone the code of grafana GitHub - grafana/grafana: The open and composable observability and data visualization platform. Visualize metrics, logs, and traces from multiple sources like Prometheus, Loki, Elasticsearch, InfluxDB, Postgres and many more.
and try build it using inside Dockerfile -
What happened?
the official Dockerfile is alpine based, not fit in redhat 8. -
- available redhat 8 fit grafana source code with Dockerfile(v9.4.7) – I find some in openshift but it falls behind for 4 versions. Tags · openshift/grafana · GitHub
- available redhat 8 fit grafana((v9.4+) docker image to pull
- Did you follow any online instructions? If so, what is the URL?
Spend one day, no good.
I’m worried about grafana would not be supported in redhat 8 as centos would stop going forward. Companies would use redhat 8 instead. In my case, I have to install using rpm way, skipping docker/kuber.
