grafana/grafana-oss:latest -
update the palette.ts file’s content to match brand theme -
In the Dockerfile…
# Dockerfile
# Start with the base Grafana image
FROM grafana/grafana-oss:latest as base
# Stage to build theme
FROM base as themebuilder
# Replace default grafana colors with our themed colors
COPY ./configs/grafana/palette.ts /usr/share/grafana/packages/grafana-data/src/themes/palette.ts
# Default stage that copies in the theme we built
FROM base as final
COPY --from=themebuilder /usr/share/grafana/public /usr/share/grafana/public
In the docker-compose.yml file…
grafana:
build:
context: .
dockerfile: Dockerfile
What happened?
theme is not updated after running the container. -
theme to be updated -
export const palette = {
white: '#FFFFFF',
black: '#000000',
gray25: '#40397D',
gray15: '#322B68',
gray10: '#261F57', // this is the panel background color
gray05: '#16113D',
No errors are thrown and when running the cloned repo on local machine, colors are updated as expected. -
volkovlabs-balena-app/Dockerfile at main · VolkovLabs/volkovlabs-balena-app · GitHub
