Dear Community members
I have created this video tutorial on how to use the Google Sheets Data source plugin to visualize and create Dashboards in Grafana
Regardless you have data related to:
- Scientific Calculations
- DevOps Operations Cost related
- IT Management
- Product Managers
- Data Analyst, Data Scientists
- Python, Matlab, Java or any other tool that generates a CSV, XLS or XLSX data format.
- More…
Link to the tutorial:
https://medium.com/@syed_usman_ahmed/visualize-excel-data-easily-using-grafana-dashboards-no-coding-required-2b89fd538bbf
It contains the guides:
- How to install and configure the Google Sheets Plugin
- How to configure the Google Sheets API Key
- 2 Examples
Link to video:
I had a moment when I was working on a community project and needed to pull data from different sheets to create a cohesive report. The plugin made it so much easier to gather and analyze everything in one place.
What helped me a lot was getting familiar with some advanced excel formulas & functions examples. These resources gave me ideas on how to structure my data and utilize formulas effectively in both Google Sheets and Excel. It was a huge relief to see my data come together smoothly, and I could focus on what really mattered—making the project a success.
Hi @rabbinray
Many thanks for sharing your feedback and experience with the plugin.
If you would like to share more details about how you use the plugin in your use-case (maybe even write a small blog post), then feel free to let me know, we can definitely discuss it together.
Cheers,
Usman
