Comma Separation for Thousand Hour Value
In the Standard options of the panel, if the hours exceed thousand in the ‘Time / duration (hh:mm:ss)’ unit, could a comma be included?
WhatsApp Image 2024-02-22 at 10.27.28_3cc439e4
As I attempted to utilize the ‘locale format’ unit, which successfully incorporates the comma as a thousand separator, but it does not apply to the hh:mm:ss unit.
WhatsApp Image 2024-02-22 at 10.27.51_ebd8e16d
Since two units can’t be used simultaneously, how can this be resolved?
welcome @norshafinahafiz
What is your datasource. I recommend doing that formatting there in the query. For example the following is with SQL Server.
What locate has time comma delimited, so unusual. Also this will most probably be problematic if you want to use it for time series.
The time highlighted with the square one is using grafana override with format time: HH,MM,SS and as you can see it does some strange things to it.
Hi @yosiasz Thanks for your reply.
This is the original time data display
What I’m trying to do is as below (red comma)
0aa51fd7acc1f153cae1d2309a962ad86c6061a1
As for the data source, in my case it is from a PostgreSQL, and the ‘time’ data extracted from my PostgreSQL database is a ‘second’ unit. It was then applied with Unit: duration (hh:mm:ss) in Grafana, and it shows a thousand hour in total.
