Custom unit to show durations
    Grafana 9.2.3 running in a docker container on debian host
    I want to Display a Bar chart that shows durations (Hours:minutes) on the y-axis
    I have a duration field (interval) from a postgres datasource.
    The query is a bit more complex, the relevant select part is this:
SELECT
  time,
  EXTRACT(epoch FROM duration)*1000 as duration,
First I divided the duration/epoch by 3600, so I would get a float that represents hours.
However this leads to the y Axis and the bar-labels showing values like 5.5 where I would prefer to read 5:30 if possible.
To solve this, I am tried to use the following custom unit in Standard options:
time: H:mm
and since the input for custom time: formats apparently expects milliseconds, I am multiplying the epoch value by 1000
  • What happened?
    The duration is interpreted as time with a timezone.
    The local timezone is used (CET which is +1h right now) and consequently a duration of 0 is displayed as 1:00 (i.e. one hour) instead of 0
    I would LIKE the value to be interpreted as duration, effectively to ignore the timezone, or simply overwrite it with UT such that 0 is 0.
is duration of type numeric?
duration should be of type interval.
it is the result of a call to the postgreSQL age function, see PostgreSQL: Documentation: 8.4: Date/Time Functions and Operators
(sorry for the late reply, only saw the answer just now)
