I have about 20 dashboards and I want it to all display all 20 in one master dashboard. Without cycling through each dashboard via playlist, is there a way I can just add them to all fit one page and display all the dashboards in one spot? Thanks!
Create new dashboard, copy / paste all panels from other dashboards into it
I can think of creating a dashboard and adding 20 rows to that. In each row, you can copy and paste the dashboard content you want to import.
Can anyone upload the sample dashboard for this, so that we can easily find out.
I had the same problem. The problem with copy and pasting is that (apart from the high number of dashboard) if you want to modify the first, you have to modify the second too.
The solution was to use Library Panels.
Credit of the solution: Sharing panels between dashboards(Grafana Community)
