Azure Grafana Managed 9 -
Build a master Dashboard from multiple other Dashboards, basically get the charts in one place -
One way I can do it so far but is not reliable it is to move variables by hand, and then export panels and import them into the Master Dashboard -
What happened?
I cant find a reliable way to do Cross Dashboard Merge -
There should be an easy way to merge multiple dashboards into one, and then customize that one as I see fit.
