Does it any one know if it would be possible or point me into the right direction?
Im trying to build a Crpto Grafana dashboard using Coincap.io API
This is their API docs.
I would start by building a backend for the Simple JSON data source that talks to the Coincap api and when you get to the stage where the Simple JSON data source is too “simple” then it is time to fork it and built your own data source.
Resources:
