CloudWatch metric math in alert rules?
Grafana v10.4.2 (701c851be7) from Docker image “grafana/grafana-oss:10.4.2”
Build an alert rule based on CloudWatch metric HTTPCode_ELB_5XX_Count (no data gaps are common)
When I build a series in a data source explorer or in a “Time series” visualization, the FILL() works well.
However, when I try to use the same function while building the alert rule, it doesn’t work.
Should I use some other ID instead of t5xx? I tried D to no avail. Can FILL()work at all in the alert rules? I saw in docs a paragraph:
If you use the expression field to reference another query, like queryA * 2, you can’t create an alert rule based on that query.
but honestly, I don’t understand if that applies here.
FILL(t5xx, 0) would produce a series with zeroes where t5xx has no values.
The error was
[sse.dataQueryError] failed to execute query [E]: metric request error: "ValidationError: Error in expression 'queryd2a8fefdcf004519a6f2d8edcb28730b': ID 't5xx' not found\n\tstatus code: 400, request id: e1fbdb41-2db1-45b7-b7a0-22b45d0f0fd0"
@jangaraj thank you for the link, it helped to solve the issue.
I run the 10.4 version, still Grafana needs the sseGroupByDatasource feature.
When I enabled sseGroupByDatasource, another problem popped up. This time with CloudWatch itself.
“Error in expression e1 [No valid range found for FILL() function.]”
Eventually, I was able to craft the alert rule. Will describe full solution here, in case somebody has the same problem.
I created one rule per load balancer. A dimension LoadBalancer=* didn’t work well. It’s not a problem to get a list of load balancers in Terraform and create the rules with a dynamic block, so I preferred doing it instead of overloading Grafana with the LoadBalancer=* dimension.
The Terraform code looks something like this:
data "aws_lbs" "all" {}
data "aws_alb" "all" {
  for_each = data.aws_lbs.all.arns
  arn      = each.key
resource "grafana_rule_group" "sr" {
  name               = "Success Rate"
  dynamic "rule" {
    for_each = toset(
        for arn in data.aws_lbs.all.arns : arn if !strcontains(arn, "/net/")
    content {
      name = "${data.aws_alb.all[rule.key].name} service=${lookup(data.aws_alb.all[rule.key].tags, "service", "unknown")} SR"
It made the Grafana’s side of the problem easier and more reliable (as far as I can tell after 12-ish hours)
First, I get RequestCount
Next, I get a 5XX count.
Next, use FILL() to replace “no data” point with zeros. The trick was to fill metrics with a “5xx” in their names. Which is only one metric HTTPCode_ELB_5XX_Count.
And finally, usual alert rule logic.
