9.4.3, grafana docker image on kubernetes -
All our grafana configuration including datasources and dashboards is provisioned.
The cloudwatch datasource gets a distinct region configured as default region.
Dashboards get “default” as provisioned region, so we only have to configure the region once, centrally, and not set the distinct region in every dashboard configuration. -
cloudwatch datasource provisioning snippet
datasources:
datasources.yaml:
apiVersion: 1
datasources:
- name: CloudWatch
type: cloudwatch
uid: ds_cloudwatch
editable: true
jsonData:
authType: default
defaultRegion: $AWS_REGION
dashboard template snippet - variable “region” configuration with value “default”
"templating": {
"list": [
"current": {
"selected": false,
"text": "default",
"value": "default"
"datasource": {
"type": "cloudwatch",
"uid": "$datasource"
"definition": "regions()",
"hide": 0,
"includeAll": false,
"label": "Region",
"multi": false,
"name": "region",
"options": [],
"query": "regions()",
"refresh": 1,
"regex": "",
"skipUrlSync": false,
"sort": 0,
"tagValuesQuery": "",
"tagsQuery": "",
"type": "query",
"useTags": false
- What happened?
Dashboard queries to the Cloudwatch datasource literally use region “default” to query Cloudwatch, which then returns empty results.
"from": "1678283651212",
"to": "1678294451212",
"queries": [
"timezoneUTCOffset": "+0100",
"intervalMs": 10800000,
"maxDataPoints": 1,
"alias": "",
"datasource": {
"uid": "ds_cloudwatch",
"dimensions": {
"Region": [
"default"
"Rule": [
"WebACL": [
"test"
"expression": "",
"id": "",
"matchExact": false,
"metricEditorMode": 0,
"metricName": "BlockedRequests",
"metricQueryType": 0,
"namespace": "AWS/WAFV2",
"period": "",
"queryMode": "Metrics",
"refId": "B",
"region": "eu-central-1",
"sqlExpression": "",
"statistic": "Sum",
"label": "",
"type": "timeSeriesQuery"
Dashboard queries to the Cloudwatch datasource resolve the “default” to the configured default region of the cloudwatch datasource, and query cloudwatch with that regions name. -
No error messages in the grafana logs or the browser developer tools, just empty data sets for literal region “default”.
So, my question is, how to properly configure a dashboard variable to use the datasources default region?
