Check function not working in browser-base ver 0.52
The check function not working while running a k6 browser-based load test version 0.52.
import { browser } from 'k6/browser';
import { check, sleep } from 'https://jslib.k6.io/k6-utils/1.5.0/index.js';
export const options = {
    scenarios: {
        ui: {
            executor: 'shared-iterations',
            options: {
                browser: {
                    type: 'chromium'
    thresholds: {
        checks: ['rate==1.0']
export default async function () {
    const page = await browser.newPage();
    try {
        // Navigate to the login page and wait until it's fully loaded
        await page.goto('https://test.legalmatch.com', { waitUntil: 'load' });
        console.log('Page loaded successfully');
        // Click the Login text
        const loginTextLocator = page.locator('.header__nav-item.top-menu__item.header__nav-item');
        await loginTextLocator.waitFor();
        console.log('Login text field found');
        await loginTextLocator.click();
        // Wait for the username field to be visible
        await page.locator('#userName').fill('crisqatest01@outlook.com');
        await page.locator('#password').fill('testqacris');
        console.log('Credentials entered');
        const submitButton = page.locator('input[value="Log In"]');
        // Ensure submitButton exists before clicking
        await submitButton.waitFor();
        console.log('Submit button found');
        // Ensure navigation finishes after login and the page fully loads
        await Promise.all([
            page.waitForNavigation({ waitUntil: 'networkidle' }), // Wait until the page is fully loaded (network idle)
            submitButton.click() // Trigger the click to submit the form
        console.log('Navigation after login completed');
        // Sleep to ensure the page renders
        sleep(5);
        // Log current URL after login to check if navigation was successful
        const currentURL = page.url();
        console.log('Current URL after login:', currentURL);
        // Additional logging: capture all visible text after login
        const bodyText = await page.locator('body').textContent();
        console.log('Body content after login:', bodyText);
        // Try to locate "My Account" element
        const successLocator = await page
            .locator("div[class='cui-label cui-g-medium']")
            .innerText();
        const elementExists = await successLocator.waitFor({ timeout: 20000 }).catch(() => false);
        if (elementExists) {
            const loginSuccess = check(successLocator, {
                'Login was successful': (successLocator) => successLocator == 'My Account'
            console.log('Login success check:', loginSuccess);
        } else {
            console.error('Login success element not found');
    } catch (error) {
        console.error('Error during test execution:', error);
    } finally {
        // Close the page safely
        if (page) {
            try {
                await page.close();
                console.log('Page closed successfully');
            } catch (closeError) {
                console.warn('Failed to close the page:', closeError);
$ K6_BROWSER_HEADLESS=false k6 run test2.js
  / __________ \  |__| \__\ \_____/ .io
     execution: local
        script: test2.js
        output: -
     scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
              * ui: 1 iterations shared among 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
INFO[0014] Page loaded successfully                      source=console
INFO[0014] Login text field found                        source=console
WARN[0014] Request successful!                           browser_source=console-api source=browser
INFO[0016] Credentials entered                           source=console
INFO[0016] Submit button found                           source=console
INFO[0020] Navigation after login completed              source=console
ERRO[0020] Error during test execution: {}               source=console
INFO[0020] Page closed successfully                      source=console
     browser_data_received.......: 11 MB  583 kB/s
     browser_data_sent...........: 224 kB 12 kB/s
     browser_http_req_duration...: avg=840.96ms min=90µs     med=203.05ms max=6.2s     p(90)=4.44s    p(95)=5.3s
     browser_http_req_failed.....: 0.00%  ✓ 0        ✗ 242
     browser_web_vital_cls.......: avg=0.007542 min=0.00166  med=0.007542 max=0.013424 p(90)=0.012247 p(95)=0.012835
     browser_web_vital_fcp.......: avg=3.15s    min=827.69ms med=1.87s    max=6.75s    p(90)=5.77s    p(95)=6.26s
     browser_web_vital_fid.......: avg=600µs    min=400µs    med=600µs    max=800µs    p(90)=760µs    p(95)=780µs
     browser_web_vital_inp.......: avg=8ms      min=8ms      med=8ms      max=8ms      p(90)=8ms      p(95)=8ms
     browser_web_vital_lcp.......: avg=3.06s    min=827.69ms med=1.89s    max=6.47s    p(90)=5.55s    p(95)=6.01s
     browser_web_vital_ttfb......: avg=390.38ms min=198.7ms  med=218.4ms  max=1.07s    p(90)=752.8ms  p(95)=914.95ms
   ✓ checks......................: 0.00%  ✓ 0        ✗ 0
     data_received...............: 0 B    0 B/s
     data_sent...................: 0 B    0 B/s
     iteration_duration..........: avg=17.52s   min=17.52s   med=17.52s   max=17.52s   p(90)=17.52s   p(95)=17.52s
     iterations..................: 1      0.052096/s
     vus.........................: 1      min=1      max=1
     vus_max.....................: 1      min=1      max=1
running (00m19.2s), 0/1 VUs, 1 complete and 0 interrupted iterations
ui   ✓ [======================================] 1 VUs  00m19.2s/10m0s  1/1 shared iters
@ankur
Hi @carlo,
What do you see when you update your k6 version to v0.54?
Thanks!
Hi, @inancgumus I’ve tried the 0.54 version and it works but something weird behavior when I try to run it in virtual machine in jenkins build looks not stable sometimes the browser will terminate prematurely.
Hi @carlo,
It’s not clear what’s not working with the check API from the description and the test. It fails after logging Navigation after login completed, but do you know which line is causing the exception to be thrown? What error do you see when working with the check API that makes you think that is the issue?
What do the logs output when the browser terminates prematurely?
Best,
Ankur
