How to check a value on a page
How to verify a value from the response page.
Example.
I want to verify the text Logout from the page using the k6 check option on the HTTP protocol level. Any options to do a similar check on k6 Browser automation?
Hi @gerardlj,
Would this example from the docs help?
import { chromium } from 'k6/experimental/browser';
import { check } from 'k6';
export default async function () {
  const browser = chromium.launch({ headless: false });
  const page = browser.newPage();
  try {
    await page.goto('https://test.k6.io/my_messages.php');
    page.locator('input[name="login"]').type('admin');
    page.locator('input[name="password"]').type('123');
    const submitButton = page.locator('input[type="submit"]');
    await Promise.all([page.waitForNavigation(), submitButton.click()]);
    check(page, {
      header: page.locator('h2').textContent() == 'Welcome, admin!',
  } finally {
    page.close();
    browser.close();
You can use page locator to check if the expected logout text is in the page.
I hope this helps :bowing_woman: Let us know if otherwise.
Cheers!
