Hi, Everyone
I would like ask how check function applied in browser based k6 load test suite, it seems it will five false positive test result after executing the test suite. The check functions should be failed based on result logs.
describe('[Load Testing - Browser]', async () => {
// Search Attorney
await searchAttorney.goto();
check(page, {
'Should be at Home Page': () => searchAttorney.homePageCheck()
await searchAttorney.searchAttorney();
// Select Sub Category
check(page, {
'Should be at Select Sub Category Page': () => subCategory.subcategoryPageCheck()
await subCategory.subCategoryPage();
page.close();
ERRO[0086] Uncaught (in promise) waiting for navigation: timed out after 30s executor=per-vu-iterations scenario=ui
✓ Should be at Home Page
✓ Should be at Select Sub Category Page
█ [Load Testing - Browser]
browser_data_received..........: 7.5 MB 90 kB/s
browser_data_sent..............: 314 kB 3.8 kB/s
browser_http_req_duration......: avg=1.18s min=637µs med=286.62ms max=9.26s p(90)=3.47s p(95)=7.25s
browser_http_req_failed........: 0.00% ✓ 0 ✗ 220
browser_web_vital_cls..........: avg=0 min=0 med=0 max=0 p(90)=0 p(95)=0
browser_web_vital_fcp..........: avg=7.65s min=6.26s med=7.65s max=9.03s p(90)=8.76s p(95)=8.9s
browser_web_vital_fid..........: avg=4.15ms min=1.8ms med=4.15ms max=6.5ms p(90)=6.03ms p(95)=6.26ms
browser_web_vital_inp..........: avg=144ms min=144ms med=144ms max=144ms p(90)=144ms p(95)=144ms
browser_web_vital_lcp..........: avg=8.35s min=7.04s med=8.35s max=9.66s p(90)=9.39s p(95)=9.53s
browser_web_vital_ttfb.........: avg=2.6s min=273.4ms med=2.98s max=4.15s p(90)=3.98s p(95)=4.07s
✓ checks…: 100.00% ✓ 2 ✗ 0
data_received…: 437 kB 5.3 kB/s
data_sent…: 4.2 kB 51 B/s
group_duration…: avg=5.99s min=5.99s med=5.99s max=5.99s p(90)=5.99s p(95)=5.99s
http_req_blocked…: avg=179.79ms min=0s med=0s max=570.53ms p(90)=539.39ms p(95)=554.96ms
http_req_connecting…: avg=87.19ms min=0s med=0s max=269.22ms p(90)=261.57ms p(95)=265.4ms
http_req_duration…: avg=3.05s min=0s med=2.62s max=7.43s p(90)=6.42s p(95)=6.93s
{ expected_response:true }…: avg=5.96s min=5.03s med=5.4s max=7.43s p(90)=7.03s p(95)=7.23s
http_req_failed…: 50.00% ✓ 3 ✗ 3
http_req_receiving…: avg=2.64s min=0s med=2.34s max=6.11s p(90)=5.59s p(95)=5.85s
http_req_sending…: avg=343.1µs min=0s med=258.05µs max=940.8µs p(90)=771.25µs p(95)=856.02µs
http_req_tls_handshaking…: avg=84.76ms min=0s med=0s max=275ms p(90)=254.3ms p(95)=264.65ms
http_req_waiting…: avg=409.9ms min=0s med=284.31ms max=1.32s p(90)=834.01ms p(95)=1.07s
http_reqs…: 6 0.072059/s
iteration_duration…: avg=1m21s min=1m21s med=1m21s max=1m21s p(90)=1m21s p(95)=1m21s
iterations…: 1 0.01201/s
vus…: 1 min=1 max=1
vus_max…: 1 min=1 max=1
running (1m23.3s), 0/1 VUs, 1 complete and 0 interrupted iterations
ui ✓ [======================================] 1 VUs 1m23.3s/2m0s 1/1 iters, 1 per VU
Thank you. Really appreciate your response.
