I am using 4 fields in a Graph panel;
AND only want to display temp & humidity in the chart, but display all 4 fields in the table below the graph.
I’ve set the series specific overides as:
Which almost works! except…
The rssi & battery attach themselves to the Left-Y axis, which results in;
- The
rssi&battery‘Units’ are fixed as percent (as used by Humidity), instead ofdb&Volts - The Left-Y Axis scale is influenced by the
rssi&batteryvalues, which makes the Humidity difficult to read.
Any suggestions please?
