would be possible to color the cells based on the value that is in the cell and the value in a different column: so if in column group_name = ALBANIA then all the other cells in this row should be 4 and so on for BOSNIA all other cells should be 48. So if it is 3 or 48 for ALBANIA or BOSNIA than color GREEN and if not exactly that number for that row then RED. Kind regards
