Hi Guys,
I am completely new to Grafana.
Came here after the installation of Unpoller and importing this Dashboard
UniFi USW: InfluxDB Dashboard
Grafana v12.0.1 (80658a73c5) - Docker Compose on an Raspberry Pi OS 12 -
Change Temperature from Fahrenheit to Celsius -
Disabling the Fahrenheit Graph and Enabling the Celsius Graph in edit mode
- What happened?
The left axis disappeared
see the left axis with the Celsius Scala like in Fahrenheit
no
