Change timezone before aggregation
Hi! For a couple of months, I am facing an issue with timezone on Grafana.
My timezone is UTC-3 (“America/Sao_Paulo”), then, for example, I have a table with the time spent doing some task for every task and I need to sum the durations to get the total time spent by day, but what I get is the result plotted in two different days when part of the tasks was done from 21h00 to 00h00 in my timezone.
I tried to use TZ(‘America/Sao_Paulo’), but I got this error:
{“error”: “error parsing query: found TZ, expected ; at line 1, char 213”}
I’ve seen that InfluxDB has already implemented this “feature”, so why cannot I use this on Grafana?
We will soon merge such a feature: https://github.com/grafana/grafana/pull/8395
Thank’s, but isn’t it only for elasticsearch? My datasource is InfluxDB.
Sorry, missed that, then there is no hope
@torkel Great to hear that! Any plan to add this feature? Thanks :smiley:
This is quite annoying if you’re using elasticsearch
